slipping away. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2004, 07:39 AM
badknuckles's Avatar
you talkin to me?
slipping away.
my th350 starts slipping out of 3rd when i drive it for long periods of time. just curious if this has happened to anyone else.
im thinking the trans starts overheating but i guess i'll have to check that out.
Old 06-12-2004, 10:26 PM
Same problem badknucles, someone should know what the cause is.
Old 06-13-2004, 09:41 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
Often when the fluid gets real hot the tranny will puke fluid out the vent.
You could have a 3rd gear clutch pack problem , sealing rings worn, a plastic govenor gear nearly worn out and the govenor slows down.
just some random ideas
