Slipping out of gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2012, 10:45 AM
Mertz's Avatar
I have a 1949 Studebaker that is stock. I got it out this spring and took it for a test drive and it keeps slipping out of 3rd gear. I had some issue getting moving in first, clutch shattered. I have always felt that the clutch was week. Anybody know if I can make an adjustment to get me around for awhile or if it is the tranny not the clutch?
Old 06-22-2012, 11:52 AM
Sounds like you have some kind of misalignment between the engine and transmission...
This puts the input shaft on an angle, hence to gear isn't engaging properly. And it naturally brings other problems.
Old 06-28-2012, 05:37 PM
Mertz's Avatar
I found the problem. The rear motor mount bushings are completely shot. Studebakers leak a lot of oil and I think that did them in.
th350 1st gear slipping camaro377 Transmission - Rearend 2 06-06-2011 03:45 AM
th400 slipping 3rd gear rolrandy Transmission - Rearend 3 04-27-2008 01:20 PM
3rd gear slipping lassebre Transmission - Rearend 5 11-18-2007 07:27 PM
th350 slipping out of third gear... flipp121 Transmission - Rearend 4 12-10-2006 02:39 PM
tranny slipping 3rd gear..... 73monte Transmission - Rearend 1 12-20-2003 02:22 PM
