Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Slipping TH350 trans
Old 12-28-2009, 07:20 AM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
Originally Posted by dirthead
I have a 76 blazer two wheel drive and the trans started to slip bad in all drive gears... I changed the Modulator Valve and it made it better but still slipping... Goes in rev. really good but you put it in drive and it will start to role but as soon as i give it some gas it starts to slip... what else could it be?
Is this a high mileage - older trans?
Any recent repair work , service work?
To lose all forward motion is a problem with the forward clutch pack usually.
Does the trans seem to hold power better from a full stop with the shifter in manual 1st gear?
