Slipping TH350 trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2009, 04:09 PM
I have a 76 blazer two wheel drive and the trans started to slip bad in all drive gears... I changed the Modulator Valve and it made it better but still slipping... Goes in rev. really good but you put it in drive and it will start to role but as soon as i give it some gas it starts to slip... what else could it be?
Old 12-27-2009, 05:51 PM
sqzbox's Avatar
My pipes are my music
Might try finding a good used Governor and put it in and see if it helps. If not, your tranny needs a rebuild. Usually when all forward gears slip and rev is good the tranny is cooked.
Old 12-27-2009, 11:05 PM
SSedan64's Avatar
More Slip diagnosis here Pg. 6 >> http://th350.netfirms.com/pages/7a2-06.jpg
Other Info >> http://th350.netfirms.com/browser.htm
Old 12-28-2009, 07:20 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Is this a high mileage - older trans?
Any recent repair work , service work?
To lose all forward motion is a problem with the forward clutch pack usually.
Does the trans seem to hold power better from a full stop with the shifter in manual 1st gear?
Has anyone adapted a Mopar trans to Chevy engine? 383ram Transmission - Rearend 26 05-19-2009 04:31 PM
th350 trans coeboy1 Transmission - Rearend 3 09-20-2006 06:45 PM
Jegs 350t trans..... No good!!!!!! tiresmoke55 Transmission - Rearend 15 08-11-2006 11:24 PM
pontiac th350 M31 auto trans poncho_paul Transmission - Rearend 2 01-13-2005 06:48 AM
T-350 slipping... low oil pressure... diagnosis? Funkster Transmission - Rearend 10 03-27-2003 12:28 PM
