slow cranking when warm - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2004, 07:57 PM
have a Ford 302 in Model A streetrod. When the engine is cold it
cranks and starts fine. When the engine is warm it cranks slowly but eventually starts. Battery/starter are new. Voltage at Starter relay dips during cranking more when warm. 8-9 volts.
appreciate any help..
Old 04-14-2004, 08:58 PM
voltage drop
what is the voltage at the starter when it is cold?? what kinda starter do you have , did you have a dfferent starter in there b 4 with the same results. also I would start to check and see where the voltage is doing all the dropping and either clean or replace different parts.
start at the battery when warm and check for a voktage drop at the conector then at both sides of the relay and then again at the starter and see what your different results are you have way to much drop. also maybe get the battery tested if the drop is right at the battery.
Jesse
Old 04-14-2004, 09:26 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Sounds like a bad starter to me, new does't mean it's good.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 04-14-2004, 09:42 PM
akm akm is offline
i was going to say coil........
Old 04-15-2004, 11:39 AM
Gardenfan's Avatar
New Member
If you have your headers running close to the starter, which I imagine you do, then you need to get a starter heat sheild. They can usually be had cheap, and are easy to install, and should fix that heat soak problem of yours.
Heat, is an electrical components worst enemy.
