Slow Hardener - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2005, 09:03 AM
Mike
Slow Hardener
Can I paint in cold weather using my slow hardener that I
got when it was hot?
Other than taking longer to harden will it affect anything else,
like how it will spray?
Old 11-16-2005, 12:49 PM
Ducky, Do a search on cold weather painting or temperature and cross linking and you will find a wealth of info
Old 11-16-2005, 02:43 PM
BarryK's Avatar
It will work but will be very slow to cure out and will expand on the flash times by a big time if you lack heat.
If you lack heat the next faster will not help you much anyway.
Old 11-17-2005, 03:53 AM
adtkart@aol.com
To expand on what Barry said, it will be harder to spray for those of us without alot of painting experience. It will be more likely to run than "lay out" as it dries. I don't like to give the paint any more time to fight me than necessary.
I like Mid-range stuff, and use heat to keep the paint room at about 80 or so when it is cooler outside. That has worked for me, but I always heat the room and vehicle/parts for several days before painting.
Just some info from an amature.
Aaron
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
slow spark on the tester jackfrost51 Electrical 1 09-08-2005 02:57 AM
Metal Glaze- what hardener? firechicken383 Body - Exterior 6 06-27-2005 09:48 PM
slow windows redneckgmc Electrical 5 12-04-2004 01:02 AM
Won't idle, Slow acceleration bjam2 Engine 1 10-15-2002 06:08 PM
