Slow shifts 03 Chevy S10 ZR2 4x4 4.3L 4l60e 139k mi - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2012, 09:02 PM
mike 96 ws6's Avatar
old dog learning new tricks
I just bought this truck a couple of weeks ago and have changed all fluids (motor oil, tranfer case, front diff, rear diff, ect) except for the transmission. I wanted to get some advice from you experts on this issue before I pull the pan.
At light throttle it shifts fine through all gears (but a little too smooth and long for me since I don't like the clutch disc sacrifice involved with slow/smooth shifts).
But at about 1/2 throttle the 1-2 shift is really slow. It seems like the normal slow/smooth shift you would expect from the factory but then it still has no definite feel of engagement for another ~1/4 second. It's like the first delay of time is being used to fill the accumulator, then more time for the apply piston to close the clearance in clutch pack.
3-4 shift is also really slow at 1/2 throttle.
Converter lock speed seems about normal (too slow for me of course).
I get the same issues at WOT but I've only tried that once because I don't wont to do any major clutch disc damage until I get this issue resolved.
My question is what is the best way to limit this shift delay time - short of a rebuild (I'd hate to go into a fully funtioning tranny when I can get another several thousand miles out of it if I treat it right)? I really can't afford a rebuild but...
BTW, the 4l60e I built for my Trans Am in 2005 with directions on here from Crosley in this thread is still alive and barking tires after several 1/4 mile passes and several thousand road miles. Thanks Crosley!!!
Old 01-02-2012, 09:15 PM
Check your spark plug gaps
How much have you drive this vehicle? I believe the ecm learns your driving habits and adjusts shift points for maximum performance. You may need to drive out for a little while to let the ecm learn your driving habits. Has the fluid and filter ever been changed? I would change out anyways and throw a can of sea foam in there after you change it.
Old 01-02-2012, 09:42 PM
I belive this issue is more extreme than what the block learn in the PCM would adjust for. I'm currently checking to see if I can obtain the same type of PCM editing software for this truck that I use on my 96 4l60e. If so I can probably minimize the clutch disc damage, but I believe that would only be masking the symptoms of a problem that exist in the hard parts/hydraulic circuit.
So, I still plan to purchase software to edit the PCM controls, but not as a preliminary fix for this issue.
The truck has indications of frequent maintenance (with the last service tag <3k miles), although I don't know about tranny service. The fluid has minimal discoloration and has no burnt smell.
Sea Foam is good stuff and has it's place, but I'd like to get to the heart of my issues rather than treating the symptoms on this one.
Thanks for your reply crussell85.
Old 01-02-2012, 09:44 PM
Opps, about 2k miles so far but babying it until I get it right.
Old 01-02-2012, 09:55 PM
joshp83's Avatar
owner of Prices Garage
a corvette servo would help but that requires to remove the x member and y pipe on a s10 you could also remove the pan take off the epc soleniod turn the allen screw a half a turn clock wise that will firm up your shifts
Old 01-02-2012, 10:20 PM
I failed to see any difference in the servo in my 96 Trans Am WS6 vs Corvette servo. Does it really make much diffence in shift time or is it just intended for better apply force?
I may adjust the pressure control if I need to but I guess I need to get a pressure reading prior to doing so.
Gee, I'm working strictly on industrial machinery these days (nothing automotive) and will need to come up with the test equipment for this transmission that I lost in a fire a couple of years ago. I'll see what I can find tommorrow to check pressures with.
Thanks joshp83! I'll post back when I find the testing equipment.
Old 01-02-2012, 11:55 PM
joshp83's Avatar
thats because all lt1s already had a corvette servo actually all 93 up f bodys had them the 700r4s are more agressive than the 4l60e with them but idt offers more clamping force and quicker shifts the servo alone will make it firmer but not harsh a 4.3 s10 with a 700r willl bark 2nd hard with a vette servo 4.3 4l60 will not
Old 01-03-2012, 08:54 AM
I'll order a Corvette servo today. Do I need to make any changes within the valve body while I'm in there changing the filter?
Old 01-03-2012, 10:22 AM
Maybe check your local trans shop for parts, you may be able to get them cheaper than the auto parts. Would a shift kit help? Or can you do everything through the ecm that a shift kit would do?
Old 01-03-2012, 11:28 AM
Yes I'd prefer a shift kit to start with, then I can make minor adjustments to the PCM.
Any suggestions for the best kit to purchase for my 4x4 application (I'm running 32x11.50x15 BF Goodrich mud tires so I'm certainly not looking to bark the tires on pavement), I just want firmer shifts than stock in order to save the clutch disc.
Old 01-03-2012, 01:00 PM
Check out "Monster Transmissions" through a google search. They may make a custom kit that works well.
Old 01-03-2012, 06:15 PM
tnsmith10's Avatar
when will it rain???
with what youre explaining here, the first thing id do is hook up a pressure gauge to see if the trans is getting line rise (pressure should go up when stepping on the gas).
also, id check it for codes with a scan tool and not just a code reader. something that will also pull stored codes.
depending on the answers to these questions will tell whether its worth it or not to go on with any service and/or repairs to the trans.
as far as if the epc solenoid is bad or not and the trans is not getting main line pressure rise, id check to see if the tps is good or not because its possible that the tps is not sending the proper signal for the pcm to control line pressure in the trans.
as far as the suggestion on turning the epc solenoid screw in, i would never turn it in more than 1/8th turn as more than that and main line pressure being too high can be hard on tcc apply and can pull the lining off of inside of the converter. there are other proper ways to fix sloppy shifts.
Old 01-03-2012, 07:32 PM
Okay, first I need a gauge set-up so let me try to find where to order that from. (got a suggestion / link?).
I'm trying to work out some issues now with the programming/scanner software supplier to work with my specific vehicle before I spend $450. If I can't resolve this issue quick then I'll take it to a shop with a scanner and post the results.
Thanks! I agree with knowing what pressures exist before I go adjusting anything. I'll get the information for TPS voltage from the scanner data stream readings and post the results. We'll go from there.
Thanks tnsmith10! I've found your directions to be very helpful in the past so I'll do my part to follow what you suggest.
Old 01-03-2012, 08:09 PM
Never mind. I just ordered this gauge.
3-5 day shipping time so I'll get this pressure info posted sometime after that.
Old 01-03-2012, 08:50 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
First thing I would do is hook up a scanner. Check two specific things: 1) trans temp, and 2) MLP... the shifter position switch.
In the internal wiring harness is a temp sensor. Sometimes you'll pull up the data on a scanner and it says -40 degrees. If its reading something that is nonsense, it needs to be replaced.
The MLP is a relatively common failure. If the ECM doesn't know what gear you've selected, its flying blind.
If both of those check out fine, pull the pan and tell us what kind of debris is in there.
... and I will assume that the speedo is working? Same thing happens with the speedo sensor as the MLP - the ECM doesn't have the proper information to make shift commands.
4L60E slow to engage 1st and reverse 72firechicken Transmission - Rearend 4 07-17-2011 11:21 PM
4l60e shifts from 1st to 3rd sceit Transmission - Rearend 7 04-14-2010 11:00 AM
4L60e 2-3 shift slow after installing kit ckucia Transmission - Rearend 3 09-01-2009 11:09 AM
4l60E Slow Reverse jadejoky28 Transmission - Rearend 4 05-21-2009 10:41 AM
transmission shifts out slow chevy hot rod Transmission - Rearend 6 01-02-2003 11:54 AM
