sludge
In my Fire Department we operate a number of older V8 diesels and they did have this problem when we changed from DELO series 300 to DELO Series 400 motor oil. The local CAT dealers shop rep. came over and we pulled one pan. He said "Sludge" and poured in two gallons of Stove Oil and told the mechanic to fire it up and let it idle at 800 rpm. They did that for four minutes and shut it down. Then they went underneath, pulled to oil pan plug and Katy bar the door. Here came the crap. Some in a thickened flow and some smaller chunks. Then we refilled the crankcase with the DELO Series 300 again and the problem went away. Then we did a repeat on every fire engine that had the sludge problem. Did it damage anything? Probably not. That was eight years ago and all are still using the same engines. I'm not plugging DELO but I know another County was using ROTELLA and had a similar experience.
Highball |
i'm always afraid that if i mess with it, that a piece is going to get loose and plug an oil passage and do some damage.
so i tend to pretend its not there. |
If you intend to reuse the cam and lifters, keep track of which lobe they come from, they need to go back the same. |
sludge
Bad Knuckles,
I have had to deal with an old Ford Y block I bought several years ago and was faced with the same issue. I called an old timer in a farm community who was a tractor mechanic. He told me to pull the intake manifold and valley cover plate and expose the tops of the lifter galleries. Then to pull the heads and remove the push rods. Once that was done to pour in a small amount of either Kerosene or Stove Oil at the top of each lifter gallery and let is soak for two days. I did it and believe it or not I was able to remove each lifter with a magnet. It can't hurt anything and if you are still researching this question give it a try. It can't hurt anything in the engine. Normbc9 |
| SBC white sludge? | Farmstore34 | Engine | 10 | 04-25-2011 10:53 PM |
| This is a lot of sludge... | K and K | Engine | 21 | 12-13-2010 01:47 PM |
| Engine Sludge | Rightytighty | Engine | 5 | 03-28-2007 10:33 AM |
| Sludge Removal | Hawk51 | Engine | 8 | 12-31-2006 03:50 PM |
| v6 engine sludge | 70chevyc10 | Engine | 2 | 04-22-2005 09:36 PM |
