sluggish - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2005, 06:40 PM
Matts99Sierra's Avatar
sluggish
i have an 81 chevy p/u with a 350ci engine. the problem is that it seems to have no power. adjusted the carb and didnt help. i put a timing light on it and the timing seems to jump about 5* ahead then back again. and i can also hear the exhaust "popping" every once in a while. i checked the plugs and they looked a little carboned up. its got brand new wires. there doesnt seem to be any problems with the vacume advance on the dist. and when i reved the engine the timing still bounced.any ideas will be greatly appreciated. thanks.
Old 02-19-2005, 07:47 PM
timing
When you check your timing with your light, did you plug up the vacuum advance? Im not sure where you intial timing should be - somewhere in the teens. 10 would be a good place to start. Then loosen and turn your dist., advancing it a little, lock it down and try it out. The jump is your vacuum advance coming in when you rev it. You can't time it properly with the vacuum advance connected.
Old 02-19-2005, 07:50 PM
ok thanks. i forgot to plug the vacume advance.
Detent cable question RObs71Nova Transmission - Rearend 9 12-13-2004 10:45 PM
Sluggish Inline 6 Cruiseomatic Engine 5 06-09-2004 10:14 AM
Running Sluggish! Fragzem Engine 3 02-24-2004 12:11 PM
Making my sluggish 5.0, 307 faster Jimgp Engine 5 12-02-2002 11:44 PM
350 sluggish Gearhead70Chevy Engine 15 11-02-2002 08:27 PM
