sm420 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2012, 09:27 PM
sm420
Hello
can anyone help i have a 54 chevy panel van with a sm420 4speed manual box but the engine is buggered does anyone khow of any engine that i can bolt on other than another 235ci I6 engine
kind regards
Gary
Old 01-27-2012, 06:05 PM
LATECH's Avatar
A few of the guys here know of an adapter company that probably has what you want. I am not knowledgeable on that kind of swap.I am sure you can adapt the engine to many trans combos. Hopefully someone will see this and chime in.
Old 01-27-2012, 06:58 PM
Wiki Edits: 31
SM-420 was used thru '72 I think. With the right bellhousing and clutch, any Chevy motor should be able to be swapped.
4-speed SM420 transmission latebloomer Transmission - Rearend 4 07-08-2010 11:12 AM
sm420 which bellhousings bolt to it? RichT Transmission - Rearend 3 12-09-2003 02:33 PM
