the sm465 will take anything you can throw at it. Its found in 1/2 ton and up trucks and Blazers. If you are building a rock crawler or fifth wheel puller, its great. It has a killer low first gear, (6.55 to 1) great for pulling stumps and 3 foot wheelies, but in a street car, good luck. Its a truck trans and not for cars. Very slow to shift too.
read about it here. |
Sm465
Actually the SM465,made by Spicer, is found in trucks,both 2 and 4 wheel drive,from half ton up to at least 1 ton. It replaced the Spicer SM420 in GM's line and is stronger,heavier and quieter,and has a provision for a back up light switch. However,for rock crawling etc. the 420 has much deeper reduction gears and a more even gear spread,making it very popular with the extreme offroad crowd. As stated though,neither of these boxes would be good choices for an auto. For a car,a better choice would be a T-5 out of a late model Camaro or Firebird. It has 5 speeds with a 5th gear overdrive,and is strong enough to handle a fairly hot smallblock or a warmed over bigblock if not driven by a maniac. If brute strength is what you need,a Muncie M-22,a Super T-10 or a Liberty 5 speed are all good medicine.The Liberty,in particular,is built for very high performance engines and is a VERY tough tranny.
Speed |
| is there a quick shifter for a muncie SM465 trans? | bullheimer | Transmission - Rearend | 8 | 06-06-2006 07:08 PM |
| Muncie Sm465 | QUICKCHANGE | Transmission - Rearend | 5 | 05-19-2006 08:37 AM |
| Suggestion on Muncie wide or close | johken | Transmission - Rearend | 9 | 03-14-2006 02:12 PM |
| A turbo 350 or a Muncie m-22? | n2o burner | Transmission - Rearend | 11 | 02-15-2006 06:47 AM |
| Swapping a Muncie SM465 to a TH-350 on a FS Chevy Truck | TL-Iguana | Transmission - Rearend | 1 | 08-22-2004 05:54 AM |
