Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - small backfire
Thread: small backfire
Old 07-30-2011, 09:11 PM
Leoman's Avatar
Leoman Leoman is offline
Maybe the carb problem is just a vacuum leak? Could be at the carb gasket, an unblocked or loosely-fitted vac port, or even the intake gaskets. If no, and if the idle mixture screws aren't at fault, might just be a bad carb.
Are you running manual choke?
