Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - small backfire
Thread: small backfire
Old 07-30-2011, 10:37 PM
lg1969's Avatar
lg1969 lg1969 is offline
Google "Tunnel Ram 406"
I think your rockers are not set properly. I adjust the rockers same way you did except i turn the crank by hand until I see the exhaust valve closes then bring the piston close to TDC. Then I tighten to push rod until there is no play then 1/2 turn for the final setting. Then go to the next cyclinder do the same thing again. And I never adjust it when it's running.
