Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Small Base Circle Cam
Old 08-28-2008, 09:03 PM
Morgan22 Morgan22 is offline
re: Small Base Circle Cam
Thanks Bogie, I was hoping you would chime in on this.
I don't want to date myself but I remember when factory roller cams came out. The rumor was that the cam profiles themselves didn't really change much from the flat tappet profiles and the gain was really only in the reduced friction of the roller lifters compared to a flat tappet. Don't have a clue if that was true or not but that is what I remember.
I will try to use the factory roller set up and see if I can find a grind to fit my 393 combo in the 1500-4500 or 2000-5000 range with about 10 to 1 compression ratio. I live in the Rockies at 5000ft so I think I can push the compression a little more up here. From here in the city you can drive to the top of the mountain just outside of town and go from 5000 to 10,000 ft in about 10 to 12 miles. Pretty dramatic change in engine performance.
