small base circle cam? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2006, 11:24 AM
dboyett38666's Avatar
I was talking to a rep. at comp. cams,and he said with my 400 small block eng. and I am running a 6" rod I would have to run a small base circle cam.I just bought a roller crane with 508 intake,and 528" lift exhaust.I want to make 500 horses at a decent rpm.Some street use but I need the motor to make as much power to compete.I have another post in title how much power should this make.I listed it last night it has all the engine specs. anyone who has built a 400 with cam rec. please post,and let me know how yours did.
I was also told when I built my 383 I would have to run one,but I had know clearance problems. Thanks
Other post with engine specs(how much power will this make)
Old 03-13-2006, 12:25 PM
camaroman7d's Avatar
What style of connecting rods are you running? Usually that's the difference. i have built quite a few 383's and the stock style rods/rod bolts can cause an issue. The H-beam and profiled rods with cap screws usually clear a standard base circle.
Royce
Last journal entry: PICTURE TEST
cam
In the engines i build, i will fix ( clearance) the rods to fit a standard cam.... I perfer not to run any small base circle cams....
Keith
Old 03-13-2006, 01:16 PM
Keith
Why wouldn't you prefer a small base circle cam
crane makes a roller 296/304 degree which is a small base circle,and it has alot more lift 539/558" 2500-6500
Old 03-13-2006, 01:33 PM
cam
Because the small base circle cam will flex.... Not bad with the lighter spring pressure but on the bigger springs it is a problem... My cam grinder will not even grind me a small base circle cam...
Keith
Old 03-13-2006, 02:11 PM
Keith
the springs i am running are 1.440" would these have to much pressure?
Old 03-13-2006, 03:00 PM
E.T. divided by $ spent= Speed
I dunno about pressure but if they are to light for the lift of the cam and rpm your turning you will get valve float at higher rpms and possibly swallow a valve.
Match your springs to the cam you use.
Old 03-13-2006, 05:14 PM
Thanks I'll check right now
Old 03-13-2006, 10:36 PM
tornado-tech's Avatar
I run a 408 with 6" i-beam rods and got a small base circle camshaft XR282 done by Comp. I know my engine builder still had to do a little clearancing to ge the lobes to clear. I went with the 1.43 986 springs (132 lbs/open and 280 lbs/closed) and 7.3" pushrods that Comp recommended at first when I had S/R Torquers but when upgraded the heads to Sportsmans, I went with 1.6 rockers, the Crane 1.46 99893 springs (130 lbs/open and 402 lbs/closed) and 7.5" pushrods. With rollers, you need to run dual springs for the spring preesure needed to handle to ramp rates. Make sure the camshaft you get also has the cast-iron gear to eleiminate running a bronze gear on your distributor and you will also need a bronze-tipped fuel pump pushrod if running a mechanical fuel pump.
Small base circle in a 434SBC?? 434SBCS-10 Engine 5 01-28-2006 04:45 PM
Chevy 383 needs a small base circle? breall Engine 7 08-06-2005 04:04 PM
small block Chevy cam choice ccnova Engine 7 03-10-2004 02:55 PM
another cam ouestion...ie...cam timing VETTE GUY Engine 0 06-28-2003 12:29 PM
