Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Small base circle cam or not?
Old 03-08-2013, 06:16 AM
Coolrider Coolrider is offline
Location: Riviere-du-Loup, province of Quebec in Canada
Originally Posted by vinniekq2 View Post
I would first
1) use a bigger cam
2)not use a split duration cam with AFR heads
the reduced base circle cam is the same price,so use one if you are worried
I know! I did read somewhere on many forums discussions that the afr 195 flow enough to go with single patern and that a 400+ sbc should be at least with 225. That's why my the other choice was the Howard's 110885-10 but, most part told it opted for the lunati for many street use reasons and Lunati suggested this to 383-400. The 110 lsa will probably not produce vacuum enough for my power brake so, i would install a Vacuum Canister.
Howard's 110885-10 specs:
Basic Operating RPM Range: 2,000-5,800 Intake Duration at 050 inch Lift: 225 Exhaust Duration at 050 inch Lift: 225 Duration at 050 inch Lift: 225 int./225 exh. Advertised Intake Duration: 278 Advertised Exhaust Duration: 278 Advertised Duration: 278 int./278 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.525 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.525 in. Valve Lift with Factory Rocker Arm Ratio: 0.525 int./0.525 exh. Lobe Separation (degrees): 110
Camshaft Manufacturers Description: Fair idle, street high performance. 2,200+ stall, aftermarket intake and headers recommended.
I wrote to Howards Cams Online Support‏ and they suggested me the small base circle version of that cam part #119995-S but, i can't find it anywhere.
