Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Small base circle cam or not?
Old 03-08-2013, 09:50 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
If you can squeeze the bank account,the roller cam is a much better choice,more power,better idle.
Before you buy the cam,you need the heads.
heads first,then match cam/intake/carb/headers.
The short block needs the CR matched and rods to fit.If you get a roller(highly recommended) then get a small base circle
what are the power figures that you want and what RPM range are you hoping to operate this engine?
The Following User Says Thank You to vinniekq2 For This Useful Post:
Coolrider (03-08-2013)
