Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - small blcok chevy! The ultimate starter problem! S.O.S.
Old 07-14-2007, 01:28 AM
sam-missle sam-missle is offline
ray, the power master starter is a very good starter, however if you do not clock it right the body of the starter will make contact with the block before the bolts actually get tight. i use these starters on all 383 engine builds and have never had one that fits without rotating the body. loosen the two allen bolts and move the solenoid toward the header to clear the block. i hope this is your problem as it is an easy fix. good luck sam-missle
