some food for thought, some blocks did not have the straight across bolt pattern only the offset style. in some cases some people have drilled the extra hole and suprisingly not 100% straight. if it is off it will, with use, pull the starter to the side no matter how tight you put the bolts. if it is factory hole it should have about 3/4 of blank and then threads. might not be your problem but check it out, if that is'nt it try re knurling the bolts for a tighter fit in the case
