small block 350 engine code - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 03-21-2011, 04:45 AM
sqzbox i would hafta say u r a genius and a life saver.
  #32 (permalink)
Old 03-21-2011, 08:09 AM
sqzbox's Avatar
My pipes are my music
Oh I wouldn't say that. I've done my share of screwing up.
  #33 (permalink)
Old 04-26-2011, 09:09 PM
lol. ima get some pics here soon. i keep finding problems with this damned truck. is it ok to use a quadrajet with and unregulated electronic fuel pump? and when i floor it the engine dang near cuts out and i let off the pedal and it pops and studders back to idle. the drivers side tail pipe is blowing a little bit of blue smoke when its cold. the drive shaft has a very crappy weld on it. only 2 bolts holding the crossmember on for the tranny. had to replace the WHOLE braking system. replaced the distributor. replaced the alternator. auto parts store gave me too small of valve covers and the drivers side one split right along the back side as soon as i started the engine. the nuts for the rocker arms keep backing off by them selfs so i go up a hill and u can hear every single rocker arm ticking away. im getting ready to just cut my losses on this pos
small block chevy engine id code help princesswz Engine 22 01-03-2015 12:15 PM
Help with Small Block Engine ID speeder2000 Engine 12 05-21-2010 05:33 PM
350 4 bolt engine block code help JC69 Engine 2 01-27-2009 06:41 PM
Big block engine code jklmbrand Introduce Yourself 3 09-10-2008 11:54 AM
Small block engine novatech Engine 19 11-10-2003 02:30 PM
