small block 350 engine code - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2011, 09:11 PM
hi i have a small block 350 and the numbers on it are: V1207DD and 1GL1369A5. no sites have these numbers at all. plz help me my firing order is all messed up.
Old 03-20-2011, 09:23 PM
i need help badly. emergency.
my small block 350 is spitting gas and flames out of the carb cause the firing order is messed up. the intake manifold says 18436572 but this is not correct. i need to know what this engine is the codes i can see r V1207DD and 1GL1369A5 plz help i need this truck running in the next hour.
Old 03-20-2011, 09:53 PM
its a GM engine
Old 03-20-2011, 09:59 PM
ericnova72's Avatar
More for Less Racer
All small block chevy's have the firing order of 18436572, there is no other order. Clockwise around the distributor cap.
Do you have a Chevy 350?? Or some other 350(Buick, Olds, or Pontiac).
Old 03-20-2011, 10:03 PM
its a GM. and its a 5.7 litre. i just put a 350 edelbrock 2102 cam in it. it was a perfect fit. its still blowin gas out of carb and now its backfiring horribly out of the exhaust.
Old 03-20-2011, 10:04 PM
ericnova72's Avatar
More for Less Racer
V1207DD - "DD" is 1969 307 cubic inch, 200 hp, 2 barrel carb, w/TH-350 trans in Camaro, Nova, or Chevelle.
Old 03-20-2011, 10:06 PM
ericnova72's Avatar
More for Less Racer
Talk us through your distributor installation procedure, your timing procedure, and your valve adjusting procedure. Sounds like it is out of time or valves are too tight.
also, what is the casting # of the rear of the block??
Old 03-20-2011, 10:07 PM
thats not correct this is a small block 350 5.7L i do know that. no offense intended
Old 03-20-2011, 10:14 PM
the valves i adjusted while the engine was off. brand new hyd lifters. assembly lube everywhere. i tightened the rocker arm nuts down till i could not turn the rod. the lifter seat for the rod was about 1mm from the retainer clip inside lifter. the distributor was installed with the casting mark facing towards front of engine. the rotor was pointing just to the drivers side of the top radiator hose. the engine turns over very nicely but its just backfiring and spittin gas. quadrajet 4 bbl with a electronic fuel pump. hei distibutor ( coil in cap). and the number 1 spot on the distributor is just to the left of the wiring connections right?
Old 03-20-2011, 10:19 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
No offense taken- but it is YOU who is mistaken.
You prolly have the valves adjusted too tight and/or the distributor 180 degrees out.
Old 03-20-2011, 10:20 PM
i dont know the rotor was pointing just to the drivers side of the top radiator hose with it at tdc
Old 03-20-2011, 10:21 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
What is the casting number and date code from the rear of the engine, top side where the trans meets the block.
Old 03-20-2011, 10:22 PM
i cannot get to it distributor and hydra vac brake booster is in the way
Old 03-20-2011, 10:26 PM
ericnova72's Avatar
More for Less Racer
Could be two things, valves too tight or timing is off. The fact that you say you could not turn the pushrods leads me to believe you may have them too tight.
How did you ensure that the engine was at TDC firing #1 so you could install the distributor?? I'm also thinking 180 out or just off enough to cause problems, one or the other.
#1 can be anywhere on the cap, as long as the rotor points to that post when #1 piston is at TDC firing.
Old 03-20-2011, 10:32 PM
i stuck my finger in the #1 spark plug hole and turned the engine over until i got compression till it stopped. the wiring connection for the cap is pointing at the drivers side fender right next to the firewall well even with the firewall.
small block chevy engine id code help princesswz Engine 22 01-03-2015 11:15 AM
Help with Small Block Engine ID speeder2000 Engine 12 05-21-2010 04:33 PM
350 4 bolt engine block code help JC69 Engine 2 01-27-2009 05:41 PM
Big block engine code jklmbrand Introduce Yourself 3 09-10-2008 10:54 AM
Small block engine novatech Engine 19 11-10-2003 01:30 PM
