Small block 350 No Oil Pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2010, 11:43 PM
Hey everyone, I just got done rebuilding my 1990 small block 350 and I cant seem to get any oil pressure. When I run the engine I get about 5 pounds, if that at idle. When I primed the motor with a drill I could see oil coming out the pushrods. To be sure oil was flowing I pulled the 12 volt coil wire and mechanical pressure gauge fitting, when cranking over the engine oil came flowing out. So I know for sure oil is flowing, but no pressure at all. I had the crank ground .10 under and installed the correct bearings. I had the engine shop install all of the cam bearings too. Also, the oil pump is brand new. Any ideas would be great. Thanks!!! , Dustin.
Old 06-05-2010, 01:11 AM
327NUT's Avatar
Did you or the machine shop install the 2 - 1/2" oil galley plugs at the front of the lifter valley, directly behind the front cover above the cam gear??
Old 06-05-2010, 04:27 AM
DoubleVision's Avatar
You may also want to check the same plugs that 327nut is referring to, they are pressed in and if there not staked they can work there way out. You may also want to check where you have your gauge installed, if trash is in the fitting or the line the gauge won`t read correctly. Or it could simply be the gauge isn`t anymore good. As usually, if one of the oil galley plugs is loose or has came entirely out, it can`t build enough oil pressure to make it to the push rods.
chevy 350 oil pressure jlangholzj Engine 15 04-20-2009 05:14 PM
Chevy Small block, low oil pressure and ticking? Help.. Bowtie_Boy89 Engine 2 02-25-2009 04:52 PM
Chevy 350 first fire - no oil pressure JoshF Engine 6 07-15-2008 09:42 AM
350 - No oil pressure at 500rpm idling topdogger Engine 9 05-06-2007 06:18 PM
chevy small block possible low oil pressure? ruski Engine 24 04-24-2006 10:18 PM
