small block 400 valve springs - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-07-2013, 01:21 PM
Mel lings valve springs #46635 Open325#@1.20", coil bind 1.160" Closed125#@1.750", 1.260"OD, .876"ID, jobber $2.15 each OR get some Is keys dual springs, with a rev kit and screw-in studs and go racing. Check valve to piston clearance if you have 1.6 rockers.
  #17 (permalink)
Old 11-07-2013, 01:40 PM
engineczar's Avatar
Again, what does your camshaft have to do with anything? No one cares what you have for a camshaft.
Congratulations you found an ovate spring that matches your cam that doesn't require machining. That is not the case with every cam/head combo.
How does that help the original poster when they don't make an ovate spring strong enough that doesn't require machining the spring seats? The spring that you suggested is for a hydraulic roller which the original poster DOES NOT HAVE.
BSE Racing Engines
  #18 (permalink)
Old 11-07-2013, 07:52 PM
vinniekq2's Avatar
Note: solid roller cams have steeper ramps than hydraulic roller cams(generally) I would also be concerned that the heads have screw in studs
  #19 (permalink)
Old 12-06-2013, 09:45 AM
I don't have a camshaft and do you have ovate springs that need machining? Is the camshaft you refer to the Reed cam Bobby wanted spec's to in 2009?
small block 400 build, valve springs
400 Small Block 86_Caprice_Wagon Engine 5 07-05-2010 09:34 AM
400 Sm Block To 409 Cu In Small Block jollyroger040 Engine 2 10-16-2007 06:37 PM
my 400 small block!! bigreed Hotrodding Basics 19 12-11-2004 01:33 AM
396 Big block v.s. 400 small block Adrenaline_Fiend Engine 13 04-12-2003 04:14 PM
400 Small Block Slick-50 Engine 8 12-30-2002 08:06 PM
