Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Small Block 400ci...or...Big Block 396ci????
Old 09-30-2002, 07:08 PM
chevyelc81's Avatar
chevyelc81 chevyelc81 is offline
Post Small Block 400ci...or...Big Block 396ci????
Which one would you go with?? Ive got the small block 400 which im planning on building up with aluminum heads(2.08in 1.60ex), 6 inch rods and a roller cam. But... I was just teased on a deal for a 396 big block bored 30 over(which makes it a 402ci) and its all redone pushing 430hp. If I got it, I would probably put aluminum heads on it with big valves and a roller camshaft. It would be pushing well over 500hp, but same with the 400 if I built that. I plan on running a supercharger also. The car is a 69 camaro which orginally had a 396 in it. Im leaning twards the 400 because I figured its lighter, but I don't know much about 396 motors, Are they better than the small block 400? The 400 has a 4.125 bore with a 3.75 stroke. The 396 has a 4.124 bore (thats .30 over) and a 3.76 stroke. Theres not much difference there. Whats the big difference becides big block and small block? Which one would you go with??
