small block big block weight difference - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2008, 08:26 AM
Jmark's Avatar
I tried this in the suspension forum but didn't have much luck. I'm about to do a total front end rebuild on my '77 1/2 ton truck. I"m considering putting in front coils from a big block truck to gain a tad of height. Not looking to shine the lights in the trees, but maybe an inch or two. Does anyone know the weight difference between a SBC and BBC? I guess I could put our bathroom scale on the driveway and then jack up the front end to whatever the weight difference is and then re-measure.
Mark
Old 02-04-2008, 08:40 AM
I think about 100 to 150 lbs.
Old 02-04-2008, 10:11 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Hi Mark, There used to be the data in the Knowledge Base but I could not find it. I will have to look around and re-list it.
Here are most of Chevy block's
Chevy Corvair flat 6 #300
Chevy 1.8-2.0 L4 #302 (4) "J car" pushrod
Chevy Chevette 1.6 SOHC #300 (also Opel)
Chevy Vega L4 #285
Chevy II 153 L4 #350
Chevy L6 194-250 #440
Chevy L6 #292
Chevy L6 216/235 #630
Chevy V6-90 229, 4.3 #425
Chevy V6-60 2.8, 3.1 #350
Chevy small block V8 #575 (generic for '60s-'70s motors)
Chevy small block V8 #535 ('59 Corvette 283 w/alum. intake)
Chevy V8 348/409 # 620
Chevy big block V8 #685 Mark IV
found it,
http://www.team.net/sol/tech/engine.html
Luv the smell of NITRO in the morning.
Old 02-04-2008, 12:21 PM
Jmark's Avatar
Thanks for the good info. So, looks like about 110 pounds difference. May have to ck into the BB springs.
Mark
can i use small block motor mounts for a big block? 402 Camaro Engine 5 01-25-2008 07:33 AM
big block or small block? jesse01 Engine 5 03-24-2005 06:16 PM
Is a 348 or 409 a BIG BLOCK or SMALL BLOCK? STATUTORY GRAPE Engine 35 02-16-2005 09:29 AM
402 big block small backfire or ??? stoneyone2001 Engine 1 04-04-2004 08:00 PM
big block in a car that had a small block bigpimp2988 Engine 4 11-20-2003 07:28 PM
