small block chev - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2003, 06:46 PM
ocoeelin's Avatar
small block chev
General info for small block chevy. I am told. all but 400. are internall balanced. Yet I replaced a motor in a 95 Yukon and it was a 350 had a weight on the flywheel. Also last week I changed a motor on a 94 chevy van a 350 also and it also had a big weight on the flywheel. If you bought a late model motor without a wheel on it how would you know what flex plate to use ? Thanx Roy
Old 08-17-2003, 06:53 PM
DoubleVision's Avatar
in 1986 chevy changed the crankshaft from a 2 piece seal to a 1 piece, in the process, the crankshaft flange was made perfectly round without any couter weights like the pre 86 shafts had, so in order to get it in balance, it had to be balenced on the flexplate.
Old 08-18-2003, 05:41 PM
ocoeelin's Avatar
flex
Then all one piece seals have a counter bal on wheel ?
