small block chev engine identication - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2013, 09:37 PM
I have a small block chev, with casting number 1401028. It also have numbers HAT3031 Vo423DMA lbn130656 stamped on the front of the of the block. What does this number mean?
Old 01-11-2013, 12:04 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Use the search function here on the board, I just did one for engine codes and got 200 hits on that alone, along with links to decoders.
Semper Fi
Old 01-11-2013, 07:09 AM
SSedan64's Avatar
Code ---Year --CID -- Vehicle ---- HP --- RPO --- Trans ---- Carb
DMA --- 79 --- 267 -- Chevelle -- 125 -- -L39 --- TH350 ---- 2-Brl
Casting # --- CID -- Years ---- HP ------- Comments
14010280 --- 267 -- 80-82 ---- xx ------ car & Truck 2-bolt Passenger stick
Old 01-11-2013, 07:36 AM
bondo's Avatar
Ayuh,.... Which translates to, it's a Boat Anchor...
Chev small block injection fat kitty Engine 6 01-10-2008 07:08 AM
Chev Small Block Viberation rackum Engine 17 09-01-2006 09:40 PM
small block into 52 chev sedan neil francis Suspension - Brakes - Steering 1 10-02-2005 08:20 AM
small block chev ocoeelin Engine 2 08-18-2003 04:41 PM
Installing a chev small block in the rear of an chev s-10 vegadeth Body - Exterior 11 07-16-2002 03:16 PM
