small block chev. heater hose routing - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2009, 09:38 PM
stanjr41's Avatar
I have a 383 in a rambler wagon. Currently the heater hose goes from the driver side front on the intake. As it is, the hose runs to the back of the motor ,across the intake ,and to the heater core.There is another outlet on the front pass. side but the a/c compressor covers it. The other heater hose comes from the water/pump side to the heater core. On the top of the w/p there is a 3/4 pipe plug. Can I use this instead of the one on the manifold.Currently this hose is in the way of everything. Is there a certain flow pattern or does it even matter?
Old 06-01-2009, 02:54 PM
fast68's Avatar
likes chevy trucks & boobies
heres the sizes:
5/8"
3/4"
the 5/8" goes to the intake manifold front
the 3/4" had two options depending on the radiator and heating options
either to the water pump top,. or to the radiator tank pass side upper
to the rad tank was usually HD cooling option
to the water pump was std and typical and most common
the intake manifold one is for the 5/8 and is always used regardless of options
you need to use the 3/4" in either the WP or the rad tank
some water pumps have a plug in the top and some dont
because some were connected to the rad tank instead
this is how the GM v-8 engines are anyways., other makes and models differ slightly or completely.
good luck!
Old 06-01-2009, 10:28 PM
stanjr41's Avatar
small block chevy.heater hose routing
Thanks Fast68. I guess my only alternative is to raise up the a/c comp and come up with a really small 5/8 90 degree fitting. The way things are now the hose and its cable to open the heat control valve(which is in that line)run right in front of the dist. And in front of the hose is the coil and the engine vac. lines for the trans.,power brakes, vac.wiper motor. It really gets busy in that small area.Also I have Griffin aluminum radiator with no extra outlets.Do you think that maybe I could use a 5/8 tapered pipe tap and open up the hole so it will go in farther ? Giving me a lower profile.Or do you know of a tight 90 degree fitting?
Old 06-01-2009, 11:11 PM
There is no such thing as a 5/8'' tapered pipe tap. [or 5/8'' pipe] What you likely have here is a 1/2'' threaded hole with a hose nipple that will take a 5/8''hose. The shortest 90* trun that can be made with standard fittings is by useing a ''Street Ell'' Its a regular 90* fitting but it ha male threads in one side and female threads on the other.
Chev Small Block Viberation rackum Engine 17 09-01-2006 09:40 PM
big block or small block ford? stangfiend Engine 3 12-10-2002 09:55 AM
Installing a chev small block in the rear of an chev s-10 vegadeth Body - Exterior 11 07-16-2002 03:16 PM
Swap small block chev into 53 ford Kasper Engine 11 02-07-2002 08:19 PM
