small block chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2012, 11:05 PM
small block chevy
I just bought a older Chevy pickup with a smallblock engine I cant determine what it is. I know its not a 350 or 305 by the look of the engine and the harmonic balancer. I tried to run the number but cant find a match. Any ideas?
Old 01-27-2012, 01:14 AM
327NUT's Avatar
Get the casting number off the left side of the engine behind the cylinder head next to the bell housing bolts. Will have 7 numbers about 1/2" high and will look something like 3970010 but not particularly those numbers.
Old 01-27-2012, 12:02 PM
techinspector1's Avatar
Wiki Edits: 326
I suspect the next thing we'll hear is that he can't get to the number to see it. If that's the case, use a telescoping mechanic's mirror and a good strong light. If the block is still factory block deck height, it probably has a stamped number on the passenger side of the block, just in front of the cylinder head. That stamped number will be more specific about where the motor came from and what it is.
Old 01-28-2012, 03:31 PM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
307 maybe a 283..
my bet 307..
Big block pil pump on small block Chevy dallam11 Engine 22 03-24-2012 07:36 PM
Can You I D a Block & Heads Small Block Chevy please? Rob Keller Engine 19 01-30-2011 08:39 AM
Big Block vs Small Block Chevy bigjoedo Engine 82 05-03-2010 03:36 PM
1986 305 chevy vs. 1987 305 chevy new style small block mtinsley Engine 2 08-22-2003 11:55 AM
55 chevy small block to big block ehchvac Engine 0 05-02-2002 08:23 PM
