Small block chevy cam
I have a cam but didn't have a spec sheet. but the cam has a purple stripe in the near the first lobe and a blue and orange in the back before the timing gear. Can anyone help me identify this cam?
There was a letter A stamp in the back and all I saw 24 on the cam and eps 6 in the end but the cam came in a super rebuild engine overhaul kit
Cam specs
Just got my cam measured it's a .414/.424 lift. I am running this cam in a chevy 327 with camel hump heads and a stock intake. How good will this motor run?
Well I mean just the combination plus I have a 350 turbo with a B&M shift kit plus have 3.73 gears in my truck
I am going to look online to see what duration it is
209 in/ 212 ex duration
Well my camel hump heads are 64cc so I should run about close to 10 to 1 compression. You think I should run a bigger duration cam?
Well the converter I have is the stock which ran good with that motor
I was thinking about using a 260H cam
Or even the famous 151 grind the 222 duration
| Big block pil pump on small block Chevy | dallam11 | Engine | 22 | 03-24-2012 07:36 PM |
| Can You I D a Block & Heads Small Block Chevy please? | Rob Keller | Engine | 19 | 01-30-2011 08:39 AM |
| big block or small block chevy | 69YENKONOVA | Engine | 81 | 05-13-2010 07:26 AM |
| Big Block vs Small Block Chevy | bigjoedo | Engine | 82 | 05-03-2010 03:36 PM |
| 1986 305 chevy vs. 1987 305 chevy new style small block | mtinsley | Engine | 2 | 08-22-2003 11:55 AM |
