small block chevy cam change - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2006, 04:00 AM
I have a 40 over small block chevy with Ross racing pistons , Lunati forged street race connecting rod and a 5140 forged crankshaft. When I first had the machining done for the engine I picked a very strong out of the whole cam to go with the turbo 400 and 3.73 rearend. I didnt notice that when putting on the roller rockers 2 of the 16 rockers were adjusted to tight.It seemed to run real strong and we took it to the local drag strip for a test day. My best 3 passes were the first 3 when I was taking it easy off the line a 13.22@103.After those first three passes I got on it a little harder off the line but rear hop and tire spin was the result. It was then that we learned that air shocks are not the best for hot rodding because they are to stiff. I was still told that a 13.22 on street tires and air shocks was very respectable. Since then I've gotten some stickier rear tires and better rear shocks. Then about 800 miles later the motor started popping out the exhaust. The 2 roller rockers that had been set to tight took no damage but the cam lobe and flat tappet lifter was ruined. I took the block out of the 80 Camaro to work on the block a little and work on the body a little more. The 80 Camaro is primed white with traces of the original blue coming through in some areas , but when it was running good it was worthy off the "Looks don't make it go" in the back window. I've invested in a new Lunati voodoo hydralic cam and cant wait to get her out again. Some of the young kids look at it like its a noisy ugly car....but the guys out there that know a little more think the way she idles and sounds , even off six cylinders at the time , know shes a strong one.
Old 05-23-2006, 06:38 AM
MI2600's Avatar
Member# 3287
Sorry, Hardsix, maybe I missed it, but is this a question or a statement?
small block chevy engine id code help princesswz Engine 22 01-03-2015 11:15 AM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
big block or small block chevy 69YENKONOVA Engine 81 05-13-2010 07:26 AM
6"rods in 400 chevy small block 406chevelle Engine 17 06-20-2003 11:14 PM
