Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - small block Chevy cam choice
Old 03-09-2004, 07:07 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
there are 2 things I would change with your combo, first off i`d loose the powerglide, your wagon is somewhat heavy and needs all the gear reduction it can get along with low end torque just to get the car moving, I would go with a TH350 tranny or better a 700R4. as for the cam if you want a lopey idle with good street manners with low end torque, a comp cams high energy 268 would be the cam for you. adding 1.6 rockers you might notice little difference.
