Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - small block Chevy cam choice
Old 03-09-2004, 11:46 PM
rifraf's Avatar
rifraf rifraf is offline
Well,you ask,I tell. get a comp 4x4 extreme cca-12-243-3 cam,at .050 its 226/234 and will need to spring for long slot 1.5 rockers,screw in studs,or pin yours,and a tci-741300 converter. If you don't want to buy more stuff,check out a cca-12-235-2,its at .050 210/218 and .447-.462 ,you want more lift I think. I would stay away from a 1.6 rocker,they stress out the lifters and cause premature lobe wear.
