small block chevy confusion - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2006, 10:54 AM
I just bought a used chevy engine advertised as a 350ci out of a 1976 suburban. It is a 4-bolt main and the block casting number (3970010) says it is a 350ci But when I run the engine code (V0628TLK), the suffix (TLK) says that it is a 1980, 400ci. I,m confused. Can anyone explain this ?
I,m trying to get an answer without pulling the heads and measuring the bore and stroke.
Old 12-26-2006, 11:13 AM
A 3970010 block certainly won't be a 400. It will be a 350. You can mis-stamp them, but you certainly won't miscast them.
Old 12-26-2006, 11:17 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Agreed. Stampings are also not very reliable. Sometimes they're just stamped wrong, but a mold doesn't make a mistake
Old 12-26-2006, 11:20 AM
(block casting number (3970010) says it is a 350ci )
This should be a 350 but it is not necessarily a 4-bolt, they made it both ways 2 & 4 bolt in the later years.
As for a 400, the harmonic balancer will have a cutout (recess)on the back side and will not be perfectly round per say (this is how they balanced them) and also the flexplate will have a weight on it if its a 400.
Old 12-26-2006, 11:51 AM
Thanks for the help
I pulled the pan, so I know its a 4-bolt. I will check the harmonic balancer.
What is the flexplate?
Old 12-26-2006, 12:01 PM
poncho62's Avatar
Wiki Edits: 5
The flexplate, or ring gear is the large gear at the back of the engine that the starter meshes with. On a standard its the flywheel.
Old 12-27-2006, 10:27 PM
Suffixes can be the same for different engines. A 400 with that suffix would have a casting number that matched a 400 block.
Old 12-27-2006, 10:32 PM
mynuffinfutsitch's Avatar
its also what the torque (or stall) converter bolts too
small block chevy engine id code help princesswz Engine 22 01-03-2015 11:15 AM
Why I have grown to hate the Small Block Chevy..... an essay Centerline Hotrodders' Lounge 316 02-08-2012 10:46 PM
big block or small block chevy 69YENKONOVA Engine 81 05-13-2010 07:26 AM
Chevy small block fuel injection homesimpsonr Engine 7 05-19-2007 04:11 PM
Chevy Small Block Heads druss32 Engine 17 05-10-2006 08:35 PM
