Small block Chevy cooling {intake gaskets} - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2011, 08:16 PM
41'srfun's Avatar
Last journal entry: 41' finally has paint on it
What is the determining factor on a SMB Chevy as far as when to use the metal restrictor tabs that come with most intake gasket sets? I did some work on a 90' TBI 350 motor recently and the intake gasket set came with the restrictors made into the gasket.
I have never seen any information as far as what year model small block requires the restrictors and when they need to be discarded. I know there has to be a reason for the restrictors, so someone please clue me in on it.
Old 07-19-2011, 08:36 PM
DoubleVision's Avatar
Never seen a factory application use them. However if a vehicle was being shipped to a year around warm climate the need is reduced as the use of the center heat riser passage is to quickly warm up the carb area which helps fuel atomization at cold start up and also helps eliminate throttle blade icing during the winter months. In the summer months the heat riser really isn`t needed. Hot Rodders believe in keeping the intake cool as possible which is why many use the restrictors or block off the heat riser passage entirely.
I`ve seen gasket sets come with the restrictors, but never installed. However since yours came that way the only answer I have is they are acting as the restrictors for the EGR valve but I could be wrong so don`t quote me on that.
small block chevy vortec heads & intake liquid launcher Engine 5 03-06-2011 06:05 AM
Small Block Chevy cooling capngrog Hotrodding Basics 15 02-19-2008 06:29 PM
Small block chevy intake swaps angryman Engine 4 06-23-2007 07:39 PM
Intake manifold for Small Block Chevy???EdelBrock Performer vs. Victory Jr. 89SDime Engine 3 03-02-2006 10:53 PM
350 small block head gaskets oldnable Engine 13 02-13-2005 12:42 AM
