We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 07-21-2008, 08:59 PM
pds23 pds23 is offline
which small block chevy cylinder head?
I am looking to buy a new set of heads for my chevy 350 engine. Currently I have flattop pistons with 882 iron stock heads with 1.94 valves. I want to add a set of heads with 2.02 valves, they can be either iron or aluminum, I just want a head to be able to run pump gas and get the best head for the money, I know that there are tons of choices to choose from. I plan on running a comp 280h cam, edelbrock air gap manifold, 650 carb and 1 5/8 headers. Any replies on a good head choice would be great. Thanks
Old 07-22-2008, 04:51 AM
automotive breath's Avatar
automotive breath automotive breath is offline
As cast use dart, iron or aluminum
CNC ported use AFR
Old 07-22-2008, 07:19 AM
454C10 454C10 is offline
What gear, trans, stall?
What model flat tops? They can vary between 12 and 5cc. 4 relief, 2 relief, or the gm stock smogger flat top that is actual one big dish.
Any idea of the deck height? (how far is the piston below the top of the block at tdc).
A compcam 280 is pretty good sized cam. It will run well with 9.7 to 10:0 cr, 3.73 gears, and a 2800 rpm stall.
Edelbrock rpm heads are nice and they come is a few different chamber sizes. Dart iron eagle 180 or 200cc are also good choices.
Compression ratio is important. You need to figure out exactly what you have before choosing a combustion chamber size.
If you plan to drive the car in the winter, avoid the rpm air gap, and just get the regular rpm. Plus I hate it when things fall under the carb when using the air gap.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "which small block chevy cylinder head?"
big block or small block chevy 69YENKONOVA Engine 67 05-13-2009 04:12 AM
Chevy small block fuel injection homesimpsonr Engine 7 05-19-2007 04:11 PM
Chevy Small Block Heads druss32 Engine 17 05-10-2006 08:35 PM
400 small block compression and head gasket question 19nova72 Engine 2 07-07-2005 09:49 PM
Small block Ford or Chevy into a W111 Mercedes 1964 220 SEb cabrera Engine 8 01-06-2005 06:58 PM
