Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - small block chevy engine id code help
Old 04-03-2009, 02:36 PM
fast68's Avatar
fast68 fast68 is offline
likes chevy trucks & boobies
0717 is july 17th
need casting date off the block to determine year
is is on top ledge somewhere same as how the block casting raised numbers code is
last number is the the last digit of the year it was cast in
for example A129 will be jan 12 '59 '69 or '79 or '89, see
and i know that it is a 70-up block because it has a TKT three digit suffix stamping code
anything '69 older was only two digit such as the other person in this thead's FC code
