Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - small block chevy engine id code help
Old 05-28-2010, 04:18 AM
a1supersport a1supersport is offline
Originally Posted by tonkaboi06
ok i am also haveing trouble with my code. i just got a 65 nova ss but i am not sure that the engine thats in it is what is supposed to be in it. heres the code:
if anyone can help i will greatly appricate it thx
Would be good if you got the numbers off the back of the block, drivers side.
P.S. Early Nova blocks had a recessed oil filter to clear the power-assist. You could use a non-Nova block, with a shorter spin-on oil filter. But blocks with the old cannister filter can't be used...unless you use an adapter to convert to spin-on filters.
