Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - small block chevy engine id code help
Old 05-28-2010, 01:26 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Originally Posted by a1supersport
Would be good if you got the numbers off the back of the block, drivers side.
P.S. Early Nova blocks had a recessed oil filter to clear the power-assist. You could use a non-Nova block, with a shorter spin-on oil filter. But blocks with the old cannister filter can't be used...unless you use an adapter to convert to spin-on filters.
My information shows the Chevy II blocks had a recessed filter to clear the clutch linkage cross shaft,... to use a non-Chevy II block with a mechanical clutch linkage several of the Nova resto suppliers sell a special aftermarket clutch pivot ball bracket to bolt to a non-Chevy II block.
Maybe it is a combo of both power steering slave clearance and clutch linkage clearance that the filter pad is recessed?? Anybody out there know for sure??
