-   -   small block chevy engine id code help (http://www.hotrodders.com/forum/small-block-chevy-engine-id-code-help-20004.html)
princesswz 07-22-2003 07:15 PM
I have a small block chevy 350 with the following codes on he front left hands side of block they are...
c4519565
v0717tkt
I know that the plant was in flint and the date was july 17th but I need to know what type of vehicle this engine came out of originally.
1BAD80 07-22-2003 07:55 PM
Please try the Knowledge Base under.. part numbers.
It will have numerous sites.
Heres a site for you that has the info.
http://www.chevymania.com/
jjpodlas 12-26-2006 11:04 AM
the TKT suffix indicates a 1974,1978 or 1980 truck.
you can search engine codes on google
home brew 12-26-2006 11:08 AM
Try here:
http://www.mortec.com/
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
poncho62 12-26-2006 12:12 PM
From this site....
http://www.nastyz28.com/chevy-engine-code-stampings.php
TKT 1974 350 conv.cab 160 4 C-10 & 1500
TKT 1978 350 fwrd cab L LS9 165 4 C-20 to 3500
TKT 1980 350 conv. cab, a/t L LS9 165 4 K-10 & 1500
tonkaboi06 04-01-2009 04:25 PM
ok i am also haveing trouble with my code. i just got a 65 nova ss but i am not sure that the engine thats in it is what is supposed to be in it. heres the code:
190199639
K0416FC
if anyone can help i will greatly appricate it thx
poncho62 04-01-2009 06:36 PM
The FC suffix relates to these engines.......
FC 1955 265 Powerglide, a/c - - car
FC 1957 283 Powerglide - 4 car
FC 1969 327 tur hydro trans. 235 2 B F
I'm thinking its a 69 327......the 55 and 57 wouldn't have the bosses for the side mounts.
lg1969 04-02-2009 12:12 PM
Sorry made mistake
fast68 04-03-2009 02:36 PM
0717 is july 17th
need casting date off the block to determine year
is is on top ledge somewhere same as how the block casting raised numbers code is
last number is the the last digit of the year it was cast in
for example A129 will be jan 12 '59 '69 or '79 or '89, see
and i know that it is a 70-up block because it has a TKT three digit suffix stamping code
anything '69 older was only two digit such as the other person in this thead's FC code
cobalt327 04-03-2009 04:47 PM
Fast68, what was the deal with the oil filter boss being raised on Nova's? I seem to remember something along those lines...
fast68 04-04-2009 11:54 PM
yah the early nova engines were like that so the oil filter could clear those chevy II chassies haha
unique blocks for those cars yeah
i totally forgot all about those til you said something haha
on a side note recently we had an old guy pull up in our shop drive with a really sharp mostly stock 64 or so chevy II nova and it had a warmed over 355 in it and it was pure bright white with all the stock trim and chrome pieces on it, and red vinyl interior that was mint condition spotless everywhere.,
the whole neighborhood was all over it checking it out
he wanted us to do a repair on one of the hood hinges.
he only gave like 1500 or some crazy sheep liek that for it and was one of those tightwads who manmages to find a steal by some crazy miracle but on purpose.
heard he sold it and now has a different old muscle car i forgot what now and got it for next to nothing as well
crazy.......
damoneric 05-27-2010 11:15 PM
similar issue
I also was looking for the chevy engine codes in order to get my problem fixed in my chevy which was bugging me for quite some time now.. found it lately. lets see if the chevy gives any further issues.
a1supersport 05-28-2010 04:18 AM
190199639
K0416FC
Would be good if you got the numbers off the back of the block, drivers side.
P.S. Early Nova blocks had a recessed oil filter to clear the power-assist. You could use a non-Nova block, with a shorter spin-on oil filter. But blocks with the old cannister filter can't be used...unless you use an adapter to convert to spin-on filters.
ericnova72 05-28-2010 01:26 PM
My information shows the Chevy II blocks had a recessed filter to clear the clutch linkage cross shaft,... to use a non-Chevy II block with a mechanical clutch linkage several of the Nova resto suppliers sell a special aftermarket clutch pivot ball bracket to bolt to a non-Chevy II block.
Maybe it is a combo of both power steering slave clearance and clutch linkage clearance that the filter pad is recessed?? Anybody out there know for sure??
a1supersport 05-28-2010 04:58 PM
My first '67 I had back in the late-80's had a 194 6cyl, which I converted using a 283 from a 65 malibu. I knew I had to dump the cannister-type oil filter and get an adapter for a screw on filter. And since front-sump nova pans/oil-pump pickup parts weren't easily attainable, the only choice I had was a deep-sump early nova "notched" pan from Milodon...but the "ram" (power assist) and hoses had to be removed.
From what I understand, the recessed oil filter was made to clear the clutch cross-shaft/linkage as well. Never saw an original set-up personally, but attained a couple of 283-nova blocks over the years. They both came from automatic-novas, but had the pivot-ball holes for clutch linkage.
On another note, my last '67 nova was converted to 4sp. by the previous owner, using chevelle parts (and a typical SBC with a normal oil filter location). Actually worked good, with one exception...the clutch fork would hit the floor pan when pushing down on the clutch. He made a notch in the floor (just to the left of the gas pedal). Geometry must have been good...that was the softest pedal-pressure I've ever felt using a three-finger clutch. No herky-jerky feel in the pedal. The orignal early-nova bell housings had the clutch fork clocked-down to clear the floor pan.
http://i22.photobucket.com/albums/b3...port/nova1.jpg
http://i22.photobucket.com/albums/b3...port/nova3.jpg
http://i22.photobucket.com/albums/b3...port/nova4.jpg
