small block chevy engines - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2002, 10:01 AM
New Member
Post small block chevy engines
Hi
I have the chance to bye a 350 small block from a 1985 camaro could some body tell me if all the wirering is needed for this model to transplant it, and if this is the model that the computer came into play,also what year did the computer era come into small blocks.
Old 06-30-2002, 11:23 AM
E.T. divided by $ spent= Speed
Post
Hey, if I'm correct the computer started in 1981.As for your 350 it did come w/ a computer.But all the computer controlles is timing and fuel(carb or inject). If your planning on dropping it in an older car all you need is a non-computer carb and a vacuum advance distributor.The exhuast manifolds will need their AIR tubes and O2 sensors plugged up.
Old 06-30-2002, 12:29 PM
New Member
Post
[quote]Originally posted by 78 monte:
<strong>Hey, if I'm correct the computer started in 1981.As for your 350 it did come w/ a computer.But all the computer controlles is timing and fuel(carb or inject). If your planning on dropping it in an older car all you need is a non-computer carb and a vacuum advance distributor.The exhuast manifolds will need their AIR tubes and O2 sensors plugged up.</strong><hr></blockquote>
Old 06-30-2002, 04:02 PM
Post
Phil 1 ,check your mail replyed to your Q.
