Small Block Chevy-Lakewood Bell Housing Alignment - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2002, 06:46 PM
New Member
Post Small Block Chevy-Lakewood Bell Housing Alignment
I have recently purchased a new Lakewood bellhousing to adapt a Chevy engine to a Forad toploader transmission. Critical to the process is making sure that the bellhousing is properly aligned. Where can you find a tool that aligns the centerline of the transmission with the crankshaft when the bellhousing is in plact?
Old 10-19-2002, 06:54 PM
Post
I use a machinist magnetic base with a dial indicator. Mount the base to the end of the crankshaft, turn the crank from the front and check the runout.
Old 10-20-2002, 12:02 AM
bentwings's Avatar
bentwings
Smile
off set dowels are available from lakwood to insure a permanent alignment. They come with a screwdriver slot so you can turn them while you are checking as above post. Tedious but necessary.
good luck
bentwings
Old 10-20-2002, 05:42 AM
SJFast's Avatar
Post
While you have that dial indicator set up it's not a bad idea to check the face of that bellhousing to make sure it's parallel to the back of the block (perpendicular to the crank centerline).
