Small Block Chevy Lifter Valley Baffle - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2008, 07:25 AM
I recently bought a rebuilt engine that has a lifter valley baffle installed under the intake manifold. I have never used one and would like to know if I should remove it or keep it? What are the pros and cons of a baffle like this? Does it actually do any good for horsepower? any replys would be greatly appreicated. Thanks
Old 08-03-2008, 07:48 AM
Jmark's Avatar
I'm not familiar with what you are describing. What engine? Do you have a picture of the baffle? Never seen one on a Chevy or Ford.
Old 08-03-2008, 08:59 AM
We use them on our circle track engines where stamp steel rocker arms are use in case one fails it keeps the lifter in place and they can finish the race and the push rod does not end up in the lifter hole either if it comes out.
When we use these we notch out holes where the push rods go through so during teck inspection we can pull one lifter out with out have to take all the rocker arms of to get the tray out.
I don't really think there is any horse power gain.
Old 08-03-2008, 02:44 PM
techinspector1's Avatar
Wiki Edits: 326
Like CNC, I don't know if there would be any power gains, but I am a fan of anything that will keep hot oil from being splashed up onto the bottom of the intake manifold.
Old 08-03-2008, 08:27 PM
King of my Man-cave.
I agree. None of the aftermarket manifolds that I know of have that nifty factory installed heat shield on the bottom of the manifold. It's not a big deal if the heat-riser passage is blocked, but I like a shield on engines where it is not blocked.
tom
Old 08-03-2008, 11:37 PM
malc's Avatar
Living At The Speed Of Life
I´m using one from Moroso.
Old 08-05-2008, 06:25 AM
corvette77's Avatar
Giddy Up
350 lifter valley baffle
I have had one in my 350 chev for 10 years, I couldn't really tell you if it's done anything for horsepower but I bought it for the reason of keeping hot oil off the bottom of the intake manifold. It was recommeded to me by a very experienced engine builder who builds beautiful cars and trucks that run 1000+ horsepower engines, so I took his advise.
small block chevy engine id code help princesswz Engine 21 01-03-2015 11:15 AM
big block or small block chevy 69YENKONOVA Engine 81 05-13-2010 07:26 AM
Chevy small block fuel injection homesimpsonr Engine 7 05-19-2007 04:11 PM
Chevy Small Block Heads druss32 Engine 17 05-10-2006 08:35 PM
small block chevy question bob cutler Engine 7 07-24-2005 10:30 AM
