Small block chevy main bearing issue (assembly) - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2008, 09:55 PM
I am trying to put a small block chevy 350 back together and the rear main bearing seems to be wrong. It does not fit over the crank. The crank is ground .010 under and the bearings match in this respect. The thrust surfaces of the bearing do not fit into the crank. The old bearing and the new bearing have the same part number stamped in the back 32020-cp. The casting number on the crank is 932442. Measuring across the bearings there was about .020 difference between the old bearing and the new bearing, with the new bearing being the larger of the two, which I am sure is the problem. I took back the first set of bearings thinking it was a defect and the new bearings have the same problem. From what I can tell from the numbers I think this is a 1975 motor. Are there different types of bearings for this? The bearing brand I am using is Federal Mogul. If anyone has any suggestions I would love to hear them.
Thank you,
Josh
Old 06-17-2008, 11:02 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
The rear main is going to be a snug fit, does the upper half seat into the block saddle OK? Are yoiu saying the cap won't go on after the bearing is in it or the bearing half won't insert into the cap?
Semper Fi
Old 06-17-2008, 11:14 PM
406 bug's Avatar
9.82 @ 139mph
The casting no. indicates a 305 or 350 crank. Both have the same 3.48 stroke and 2.45 main journal. Have you installed all the mains with bearings whitout the crank and measured the difference between the crank journal. Is the crank the same one you removed form the engine??
Old 06-17-2008, 11:17 PM
with the bearing in the block, the crank will not sit in the bearing. The bearing also will not go onto the crank outside of the block because it does not fit in between the thrust surfaces.
Someone else suggested that the bearing is intended to work with a crank where the thrust surfaces have each been machined .010". I like this theory because the numbers check out. So I think I need a bearing that is .010" on the diameter and standard width on the thrust. Anyone know where one could find such a bearing? None of the parts houses have asked for the measurement across the bearing.
Old 06-17-2008, 11:19 PM
I think I understand the measurement you are after, and do not think I have the tool to measure this. I have a vernier caliper and plastigauge to work with as far as measuring goes. This is the same crank that I took out of this block.
Old 06-18-2008, 10:17 AM
boatbob2
bearings...
Hi,i dont have a suggestion,but,why not take the crank and brearings to a good machine shop,and ask them.im sure an automotive machine shop has the answer.
Old 06-18-2008, 10:29 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Are you suggesting that the thrust surfaces need to be machined .010 under? Because that is definately not true. There is a chance you just got a bad rear main bearing. stranger things have happened.
Old 06-18-2008, 01:28 PM
King of my Man-cave.
What it the part # of the bearing set you have?
tom
Old 06-18-2008, 06:44 PM
I am thinking that the bearings were intended to go with a crank where they have been, but that this one is not. I got another set of bearings that I think are right. I will let you know how it works out.
Josh
Old 06-20-2008, 06:14 PM
Everything went together perfectly with the new bearings with a standard thrust surface. Thank you for the help.
Old 06-20-2008, 06:20 PM
Thank you very much for posting your results.
tom
Old 06-20-2008, 06:22 PM
tom
No problem, I hate it when a search turns up the same problem with no resolution.
Why I have grown to hate the Small Block Chevy..... an essay Centerline Hotrodders' Lounge 316 02-08-2012 10:46 PM
big block or small block chevy 69YENKONOVA Engine 81 05-13-2010 07:26 AM
Big Block vs Small Block Chevy bigjoedo Engine 82 05-03-2010 03:36 PM
Chevy small block fuel injection homesimpsonr Engine 7 05-19-2007 04:11 PM
Chevy Small Block Heads druss32 Engine 17 05-10-2006 08:35 PM
