Small Block Chevy Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2008, 11:19 AM
I HAVE A SMALL BLOCK CHEVY MOTOR, AND I BELIEVE IT IS A 1970's 350 BLOCK.
THE BORE MEASURES 4.00", AND THE NUMBERS ON A VERY VAGUE,
ITS EITHER A 350,HI OUTPUT OR A 350 THAT WAS USED ON TRUCKS AND VANS.
THE MOTOR HAD 1.94 HEADS ON IT I DONT KNOW IF THAT WAS STOCK FOR THE MOTOR OR ADDED LATER, IT ALSO HAS A 8" HARMONIC BALANCER.
CAN ANYONE HELP ME OUT WITH WHAT THIS MOTOR MIGHT BETHE CASTING #ON THE BLOCK IS 3970010 THE BOOK I HAVE SAYS ITS A 350 IT ALSO SAYS ITS EITHER LOW POWER 185 OR A HIGH POWER 370 IAM ASUMING THIS TO BE HORSE POWER IT ALSO SAYS IT CAME IN EITHER 2 OR 4 BOLT MAINS , MINE IS A 2 BOLT, IT ALSO SAYS IN CAME IN A CAR TRUCK OR VETTE MANUFACTURED BETWEEN 1969 AND 1979.
THE NUMBERS ON THE HEADS ARE 333882.
ANY HELP WOULD BE GREAT
THANKS
Old 03-18-2008, 11:26 AM
Jmark's Avatar
The 010 block is a basic 350 block. Nothing too special but a good builder. Chevy made millions of them. I have 2 running right now.
The 882 heads (running a set right now also!) are the mid 70's smogger heads. 76 cc chambers. Good stock head and still lots to be had. Overall, just a stock smogger 70's engine.
Mark
Old 03-18-2008, 11:29 AM
re: Small Block Chevy Question
According to Mortec.com the heads are: 74-80...350/400......76cc chambers. The block could be anything:
3970010....302.....69....4...Z-28 Camaro
3970010....327.....69....2...Trucks and industrial
3970010....350...69-80...2 or 4
If you can make out the numbers stamped on the pad to the left of the water pump, it can be narrowed down. You can also go to the Mortec site and it'll show you where to find the casting dates
Big Block Chevy combination question JamesRS Engine 13 01-22-2011 08:08 PM
big block or small block chevy 69YENKONOVA Engine 81 05-13-2010 08:26 AM
My 350 Small Block Chevy. What do I have? Frank the Tank Engine 29 09-08-2007 07:33 PM
chevy block question joesnova2 Engine 15 05-01-2007 10:20 PM
small block chevy question bob cutler Engine 7 07-24-2005 11:30 AM
