The compression ratio will be very very low.
Change the pistons or get a blower. In a 305, that cam will shift the torque curve way way up. The little 305 won;t get busy until well after 3000rpm. You'll want a 3800-4000 rpm stall 9" torque converter and 4.56 gears to make use of the RPM cam in a 305. Thats assuming you correct the compression ratio. Right now its way, way way too low. Stock 305's come with 52 to 58cc heads. With 64cc heads your cr will be a good bit lower than stock. If you were to swap the pistons for some KB144 domed pistons and use a thin shim style .015" head gasket (felpro #1094) your cr would be in the ball park for that cam, using 64cc cylinder heads. {Assuming a stock .025" piston deck clearance 9.9:1 cr} You'll need to recurve the HEI distributor mechanical advance curve so it has more initial base timing (24++ at idle) and a quick curve to 36deg total. Might even try locking out the advance curve for 36deg fixed timing. Other wise the low end and throttle response will be pretty weak. If you cannot do all this, then change the cam for a much shorter duration cam. that matches your low compression ratio and mid 3.?? gearing and budget. Save the big RPM cam for a high compression motor. Last edited by F-BIRD'88; 08-14-2008 at 04:05 AM. |
If you are not going to make the changes nesessary to allow the cam to work then you are really really much better off with a (much) smaller cam. You can always slip the rpm cam in later once you make the nessessary compression, porting , rear gear ratio etc changes. Without these other parts of the "combination" its going to be a dog. It all has to work together. |
64 cc vs. 76 cc heads
i know a 305 with there stock heads are 58 cc chamber an carry a 8.5 to 1 so ur likely a 7.5 to 1 using the 64 cc chambers could shave the heads down 10.000 help bring it up some one thing you wont have to worry about gas ratio no valve pinging thats for sure! and if there stock chevy heads there 1.94 intake valve an 1.6 exhaust valve i took a set 305 heads cut out to fit in 1.94 intake valve an 1.6 exhaust to up my compression ratio!
chevy 305 heads
the 305 intake valve size is 1.88 an a 350 or 327 1.94 both use the same exhaust size 1.50 and yes the chamber is smaller if were my heads i'd do a bowl blend in the valve pocket and gasket match the intake ports and rase the roof on the exhaust ports will help you out alot with your motor!
305 heads
they'd work ok but they'd be better if you blended the valve bowl cut away the casting mold line causes restriction in the valve flow but you can just leave them alone if you like but bowl blending helps out alot at least give you 10 to 15 horse power gain
It's going to be a major dog. That comb needs much more cr, much more gear, and much more stall. And it needs long tube headers!
You will have a hard time getting that combo to idle in gear with a stock converter. It needs a 3000 rpm stall. Do yourself a favor and get a much smaller cam to match the low compression and a 2400 to 2800 rpm converter to match the torque of the 305 and the low 300 series gears. If you plan you spin the tires at all, get a cam with about 205 degrees duration on the intake, 210 on the exhaust, and 106 to 108 LSA. I would also use a stock set of 305 heads or use a thin gasket with the 64cc heads. You can find 305 vortec heads for cheap. You really need to get the compression ratio up or buy a super charger. |
305 w/ 350 heads
I personally would stay away from that idea. The stock 305 HO didn't produce that much power anyway. the HO motors (ss monte 86) came with 58cc double humps, with 1.84/1.50 valves, and they were mabey 8.5:1-9:1 at best. with 350 heads your gonna be down to like 7.5:1, assuming they really are 64cc heads. Do you know a casting # for the heads you planing on using, because most of the 350's i've seen have 76cc heads stock, exept the old fuelies but if you got those, they should have 2.02/1.60 valves. Did you give the adv. duration on your cam? that cam could end up dropping your compression even more. I persanally have like 6 sets of the 305 HO, i'll sell you a set for $40 IF U want them. any way, if you do this, IT WILL BE A DUD!!!! something's gotta change, flat tops, domes preferably or you will be very dissapointed. If u really wanna get the power get the DART iron eagle 49cc heads, w/ stock dish piston, and your cam, you might see 300HP. get at me if u need some 305HO heads, i just don't wanna see you waste your time.
Danny |
cam swap
you got 2 options after you get the accesories outta your way,
1).remove motor mount bolts, remove tranny crossmember and lower the tail shaft of the tranny to the ground, this should bring the front of your motor up high enough to do the swap 2). i missed what car its in but you might be able to just pull the radiator out and get enough room that way in a LARGE vehicle. |
| small block chevy engine id code help | princesswz | Engine | 21 | 11-19-2012 06:10 PM |
| Why I have grown to hate the Small Block Chevy..... an essay | Centerline | Hotrodders' Lounge | 316 | 02-08-2012 10:46 PM |
| big block or small block chevy | 69YENKONOVA | Engine | 81 | 05-13-2010 07:26 AM |
| Chevy small block fuel injection | homesimpsonr | Engine | 7 | 05-19-2007 04:11 PM |
| Chevy Small Block Heads | druss32 | Engine | 17 | 05-10-2006 08:35 PM |
