Small Block Chevy starter bolt hole - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2002, 12:10 PM
Question Small Block Chevy starter bolt hole
Ready to assemble short block I find that the outer starter bolt hole has a piece of casting broke off. It's not much and It's in that 3/8 inch section where there are no threads. 383 stroker 9.8 comp, should I get It brazed or not worry.
Thanks in advance
Old 11-12-2002, 01:28 PM
4 Jaw Chuck's Avatar
Post
How big of a piece? I doubt it will matter if the threads are all there. This section if I understand you right is for bolt location mainly and is not critical.
— Han Solo
Old 11-12-2002, 03:22 PM
Thumbs up
Thanks for the reply 4 Jaw, the piece Is probably the size of your pinkie nail. And now that I read your reply It makes sense, the blank section before It becomes threads Is for aligning up the bolt. Thanks again.
Old 11-12-2002, 06:25 PM
E.T. divided by $ spent= Speed
Post
I'd put a lil locktight on though,just for sts and giggles.
Old 03-10-2003, 07:14 PM
Jared's Avatar
Post
If you use the block make sure to use the 3rd starter mount with it. I had to scrap a block because the starter wouldnt hold due to the outer hole being chiped. The bolt threaded but when torqued on would allow the bolt to move and the starter would throw its self far enough out of position to grind and not turn it over. Its no fun laying in snow tighting up a starter on a camaro. Id try to fix it before it breaks further or becomes a problem hope yours turns out better than mine.
