Small Block Chevy valve lash - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2012, 07:13 AM
When you hit zero lash (by spinning the pushrod, etc.) during adjustment of hydraulic lifters, how many turns on the nut do you go past that point to center the lifter plunger? I read 1/4 turn, 1/2 turn and even a whole turn. So which is it? I've seen varying accounts in both forum post and servive manuals. Thanks.
Old 04-27-2012, 08:31 AM
chevynut1's Avatar
I have always done it 1 full turn, 1/4 turn at a time pausing between turns. Hope this helps.
Old 04-27-2012, 04:29 PM
The common factory setting was 1 turn but it has been my experience that performance hydraulic cams work better with 1/4 to 1/2 turn. Your results may vary. The ABSOLUTE MOST IMPORTANT THING is making sure you are at zero lash before you adjust. It's easy to miss, especially with new lifters.
Old 04-27-2012, 05:28 PM
Well, its stock 305 so I'll do one turn. I'll also do the "jiggle the pushrod up and down" method to find zero lash as opposed to spinning it. Thanks for all the help!
how to fix valve lash and timeing with chevy 350 in truck? snmpty Engine 5 02-26-2012 10:26 AM
small block chevy valve adjustment echristmansr Hotrodding Basics 4 09-26-2011 12:25 PM
Hemi looking valve covers, that bolt on to a small block Chevy markedwarde Hotrodders' Lounge 101 12-01-2008 06:05 AM
350 chevy, rockers, valve lash and a idiot (me!) :-( astrosteve Engine 10 06-03-2006 02:20 AM
Valve Covers on Small Block BigMac Engine 4 09-23-2003 06:43 PM
