small block ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2012, 05:18 PM
small block ford
Can anyone help on a upgrade on which ford 302 small block engine {crate engine, dart,world,!!!!!!!!!} in 32 roadster drivetrain at present is small cam,edelbrock alloy heads,rollers rockers,pistons unknown,straight lpg, c4 tranny, nine inch 3.1 gears and just has not got that go ,is a crate motor the way, need some advice thanks the aussie
Old 01-13-2012, 03:52 PM
did you try timeing adjustments, checking your fuel flow, is it carb or injected, compression values, or your cam might be to small to open your valves of your alloy heads all the way. id check the small stuff first my self. sounds like a easy fix just not enough info to make a proper diagnosis.
Small block ford genewa1 Hotrodding Basics 10 12-06-2012 03:20 PM
ford small block in 48 ford pu what headers hemivolvo Engine 0 07-20-2007 04:02 PM
small block ford Rickyrat Hotrodding Basics 3 02-05-2005 09:42 AM
small block ford Rickyrat Engine 11 01-23-2005 08:01 PM
Ford Small Block I.D. nightrain_rod Engine 5 12-02-2003 10:16 PM
