Small Block Ford Dist. bushings - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2007, 08:44 PM
Anyone know where to find the shaft bushings for an old points type Ford small block dist.? The local parts houses don't carry them anymore and I haven't been able to find any on the internet either. Everyone wants to sell me a complete rebuilt dist. Are the later model bushings the same?
TIA
Old 09-10-2007, 09:30 PM
woodz428's Avatar
Troll Hunter
It must have some miles, I haven't seen too many with the bushings worn out. I believe that the main body ( as well as the bushings) were the same until the TFI. Unless you want to keep the body part#, you could use any SB body and stick your guts in it. I'll see if I can locate a #...have you checked the Mustang parts houses...that would be a good source.
Old 09-12-2007, 09:47 PM
Thanks 428, I didn't know if they were the same or not. I'm building a motor for my old Model T and wanted it to look '60's vintage. Have several old points dist. from the junk yard that are "junk". Was going to try to put one together with a petronix unit but can't find one that hasn't been worn slap out.
Here's a pic of my Model A with a 428 in it.
Old 09-13-2007, 12:18 AM
aka Duke of URL
Maybe find a local rebulider in your area or have the bushings made?
Old 09-15-2007, 04:30 AM
Don't know of any rebuilders around here, everyone wants to sell me a complete dist. I could turn some out but don't know if the old lathe could hold the tolerance any closer than the worn ones. There have to be some out there somewhere or they couldn't be rebuilding the old distributors.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Small block Ford steering conflict rhphotrod Engine 5 07-27-2007 03:32 PM
ford small block in 48 ford pu what headers hemivolvo Engine 0 07-20-2007 04:02 PM
small block ford Rickyrat Engine 11 01-23-2005 08:01 PM
Swap small block chev into 53 ford Kasper Engine 11 02-07-2002 08:19 PM
